Fluent Licensing issue
1 Attachment(s)
Hello all,
I recently got a Student ANSYS 15 license (June) and I registered it on my laptop. I run the Licensing Utility and I get the attached licensing error. Even though when I run the license wizard, I select the license file (on the desktop of my laptop, the same machine on which I am trying to run ANSYS Fluent) and it says "no new license found, so not installing a new license." I know this is an Ansys issue, but they don't provide technical support for Student licenses, except for an FAQ that just tells me to refer to an advanced licensing guide which I can't find. http://www.ansys.com/Support/Licensi...icensing+Guide And this is what they give me in the help files installed on my laptop, after I try to set the License Preferences for User Abyss, and trying to select version 15: Quote:
I have a hunch that somehow when I installed the ANSYS package, it got set up so that the "FlexNet and ANSYS Licensing Interconnect components" get started separately, and one or the other isn't actually being started because I have no idea what those two things are. If that's the case, does anyone know how I "verify that the license filed has been cached"? |
Btw, did you remember to install with admin privileges?
Also, make sure you are running ANSLIC_ADMIN utility with admin privileges. Most of the options will be disabled if you are not admin. To verify if licenses are working properly. Go to view status/diagnostics option and click display the license status. I also have always have an issue with the license server after a restart. I have to manually stop and start the license manager or it does not work. |
Yes, I am logged into the administrator account on my laptop (the only account available), and even when I right-click-to-run as Administrator on "Client ANSLIC_ADMIN Utility 15.0" I still have most of the options blocked out.
I cannot manually stop and start the License Manager because that option is blocked out. And when I get it to allow me to run the License Wizard, the process fails because it says that it cannot stop the License Manager (since the wizard tries to stop and start it), but it does not state WHY it cannot stop the License Manager. Edit: When I "Display the License Status" the utility does this output: Quote:
There are two shortcuts:
If you are seeing Client ANSLIC_ADMIN Utility then that means you do not have the license server software installed on your machine. That is, you do not have a license server setup. The correct shortcut is Server ANSLIC_ADMIN Utility. The license server installation is done separately from the rest of Fluent & Ansys products. But the files are on the same installation disc, iso, or package that you have (run setupLM.exe instead of setup.exe) Maybe you already have it installed, but make sure you are running Server ANSLIC_ADMIN Utility and not Client. The client utility does not give you the server options because it is not a utility for running the server, it only controls the client. |
Eureka!
That has significantly clarified my issue. I ran setupLM.exe and successfully installed Server ANSLIC_ADMIN Utility. It does look like I will have to do this frequently, whenever I: 1. Right click, Run-As-Administrator on "Server ANSLIC_ADMIN Utility" 2. Run License wizard (where I skip the first two steps, because my license is the same, and my server is the same) and it Successfully (finally!) Stops and then Starts the License Manager. Hoorah! Thanks so much. Now I definitely understand how to fix my problem, and I kind of understand what the actual problem is. :p |
