November 22, 2014, 13:40 |
having problem regarding the specific paper
Munib Qasim
is the value of wall flux and the temp of fluid matters or we can assume any value?
i am trying to make simulation for the given below conditions and assumptions,diagram is also available " Approach (In Paper) · Flow: periodically fully developed turbulent flow, under constant heat flux(during analysis I had not given any value of flux to wall ,0 by default). · K-e turbulence model Assumptions(In Paper) · Air is flowing · Corrugation angel is 20 · 1200>Re<4000 · Dia is characteristic length · Turbulent with constant properties · 31*81 grid size · No slip condition · Uniform velocity at inlet · Fluid is incompressible · Press at outlet · Aspect ratio is .182 " for Re 4000,if i am assuming these values Sr # aspect ratio Density Velocity Length Viscosity Reynold # Kp Kf Cp(fluid) Tp (K) Tf (K) 1 0.182 0.8 100 0.005 0.0001 4000 202.4 0.0242 1006.43 300 441 what will be the values of constant wall Flux? and the temp of Fluid at the inlet. Thanks for your time and also will be very thank ful for the positive feed back. |
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 10 | February 7, 2024 21:50 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Can I solve this problem by Fluent? | Kai_kc | FLUENT | 1 | October 27, 2010 05:29 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
How to reference paper which is in review | Zonexo | Main CFD Forum | 4 | June 10, 2008 23:13 |
