Investigating the conductive heat flow INSIDE a solid |
July 13, 2017, 08:15 |
Rep Power: 9 |
My problem is simple : I would like to define a plane tha tcuts across a solid, and monitor the heat flow going through this plane (i.e. inside the solid, and not on a wall) I am quite confused as to how to achieve that with CFD-post... The wall heat flow is available, but only between two different solids. Is it possible at all to investigate the flow inside one solid ? |
July 13, 2017, 10:03 |
Onur Özcan
Rep Power: 12 |
send your model and clearly see what you would like to do
July 13, 2017, 10:14 |
Rep Power: 9 |
Sorry, this will not be possible for confidentiality issues.
Just imagine one box-shaped solid. In post-processing, I defined a a plane "slicing it in half". I would like to know the heat flow going through this plane. The difficulty being that this plane is not a wall between solid. Is this clear ? |
July 15, 2017, 20:26 |
Aureliano Sancho
Rep Power: 12 |
Maybe one way of you do this it's to create in DM the two solids (the two part of you model) and join how single body, selecting both and click with right button and join the bodies, it works.
July 24, 2017, 02:46 |
Rep Power: 9 |
Yes, that was the first thing i thought of to.
But it would be quite a tideous solution for me. It would actually imply to modify several geometries for me (different configurations), re-edit several meshes, and redo a lot of computations. With no better solution, i will do that, but i was hoping to find an easier way... |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Thermally coupling 1D gas flow to 3D heat conduction in solid | Pyotr | CFX | 5 | March 6, 2017 21:46 |
[blockMesh] 3D laminar flow in a pipe with a solid object inside | clint | OpenFOAM Meshing & Mesh Conversion | 1 | November 28, 2016 12:45 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
