Ceiling fan modelling using MRF method in ansys fluent |
December 4, 2014, 04:46 |
Madushi Rajapakshe
hi, i am working on simulating air flow pattern of the ceiling fan.
In MRF method under frame motion i tried simulation giving -20 rpm and +20 rpm as the rotational speed . For both two cases flow pattern shows upward velocity vectors in solution. any suggestions to make this flow vector in downward direction? thanks in advance |
ansys, ceiling fan, fluent, frame motion, mrf |
UDF for ANSYS Fluent and Runge Kutta Method | cagri.metin.ege | Fluent UDF and Scheme Programming | 3 | January 24, 2020 03:46 |
Results are different for Ansys Fluent 14.0 and Fluent 6.3 | syavash | Fluent UDF and Scheme Programming | 1 | February 17, 2013 01:09 |
gambit in Ansys FLuent 13 | saharesobh | FLUENT | 0 | August 1, 2012 15:30 |
[GAMBIT] 3.5 years overtake by Ansys: Where are the enhancements in grid generation | Volker P. | ANSYS Meshing & Geometry | 22 | January 17, 2012 17:27 |
Loading of Temperature datas from ansys to fluent! need help!! | tensun | FLUENT | 0 | November 6, 2010 00:35 |
