December 13, 2014, 04:13 |
How to evacuate only species on the outlet
Astio Lamar
Rep Power: 13 |
Hello!
I have a case in fluent that I try to simulate contaminant with the species transport. I am wondering, if it is possible to filter the species over the outlets and evacuate them without evacuating the air? Thanks. |
December 13, 2014, 11:07 |
Lucky
Rep Power: 65 |
I think yes. You can set permeability for different species. This should let you make the outlet permeable to your contaminate and impermeable to air.
December 14, 2014, 05:58 |
Astio Lamar
Rep Power: 13 |
Hello and thanks for your reply.
Would you please explain more. As far as I know, we can set the percentage of the species for the backflow over the outlets! |
December 14, 2014, 12:29 |
François Grégoire
Rep Power: 17 |
I think you have to set up the species transport with user-defined scalars instead of using the species transport model. When you model species transport through user-defined scalars you get to specify a scalar value or a scalar flux at outlets.
See the attached picture, user scalar 0 would have a specified value = 0 at the outlet while user scalars 1, 2 and 3 would have a typical convective and/or diffusive flux specified at the outlet. Look for the tutorial Using User Defined Function (UDF) with ANSYS FLUENT Tutorials : UDFs for a User Defined Scalar on the Ansys customer portal to learn how to set up species transport with user-defined scalars. |
Unexpected species increase in discontinuous phase | CeesH | Fluent Multiphase | 0 | August 6, 2014 05:41 |
Temperature at a velocity/mass flow outlet | saisanthoshm88 | CFX | 1 | July 8, 2014 18:35 |
Species mass flow inlet | lorenz | FLUENT | 3 | March 15, 2012 07:26 |
Outlet Problems | Cyberholmes | OpenFOAM | 5 | August 4, 2011 11:31 |
outlet boundary condition | neil | CFX | 1 | June 17, 2002 00:57 |
