Dynamically changing boundary conditions
Old   December 16, 2014, 01:33
Default Dynamically changing boundary conditions
DamR is on a distinguished road
Is there a way to set up a dynamic inlet boundary condition. Lets say I have a velocity inlet. A transient simulation runs for "x" secs with an initial velocity at inlet and then based on the response, I have to change the velocity at inlet for another "y" secs. Is it possible to do this? I want the change in velocity to add value to the previous simulation rather than start from scratch.
I would be using Matlab for the control system and will be juggling between the two (Fluent and Matlab) to get the final simulation.
DamR is offline   Reply With Quote
Old   December 16, 2014, 10:35
Andrew Kokemoor
Kokemoor is on a distinguished road
Profiles (Fluent User's Guide 6.6.5) may do what you're looking for, depending on the interaction you need. If that's not powerful enough, you can write a DEFINE_PROFILE UDF.
Kokemoor is offline   Reply With Quote
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 04:59
Changing boundary conditions during LES faisal_durr Main CFD Forum 1 April 30, 2012 08:02
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
