Cyclone Simulation Convergence Problem
Old   July 26, 2007, 07:31
Default Cyclone Simulation Convergence Problem
Sal
Hello every one.
I am simulating a cyclone seperator and I have easily got convergence using K-E, K-E RNG both first and second order discritization. Using the RSM model i can only get convergence for first order but cant seem to get convergence for second order. I am using 517000 tetrahedral cells in the mesh. Can some one help me on this please Thank you in Advance.
Sal
Old   July 26, 2007, 08:07
Default Re: Cyclone Simulation Convergence Problem
Joe
Restart the RSM solution from a converged two equation solution. Adjust your under relaxation factors.
Old   July 26, 2007, 08:15
Sal
Should i start it from the first order discretization. Steady, unsteady, boundary conditions bottom outlet as wall or pressure outlet and if unsteady what would u recomend the time step to be and should I use transient controls and which one? I appreciate this.
Sal
Old   July 26, 2007, 12:00
Bubble
I would recommend that u start using steady state first to build up pressure to create a swirling flow. Once the residual gets stable change to unsteady state because the vortex will move in quasi periodic movement. You can adjust the time step to get better convergence or u can adjust your relaxation factor.
Old   July 26, 2007, 18:18
Sal
For the bottom wall what do you recomend me to use as a boundary condition. At the moment it is defined as a wall. Do i need to change? if yes what to and would I have to enter any other parameters. Thank you for the help in advance.
Sal
Old   July 27, 2007, 08:16
Sal
While running the boundary conditions i get no reverse flow. Does any one know how to correct this. Thank You. Sal
Old   July 28, 2007, 01:53
JSM
For cyclone, there are some basic steps in CFD.
1. For meshing - Always use structured mesh (hexahedral elements) with aspect ratio within the range 5 to 10. 2. solver setup - RSM turbulence model is recommended. First solve with default setup with RSM. Once converged, then go to higer order discretization with increased converge monitor 1e-6. 3. Choose time setup size as analysis should converge in every time step.
Note: first order converged solution always gives some appropriate values. dont worry about. Cyclone phenomena is purely unsteady. So unsteady with higher order discretization, you can more accurate solution.
Old   December 17, 2014, 03:32
Default Another viscous model besides rsm
fatih syakban
fatih-ITS is on a distinguished road
Iam still running Cyclone with double inlet with section angle 30 degree, 2 phase coal and air
Iam going to asking too, can I use another viscous model like k-epsilon realizable to get correct separation efficiency and pressure drop ??
Can you give me advice setting for double inlet cyclone to me ?
because Iam very depressed with my final assignment,
Thank you for your attention
Originally Posted by JSM
;143944
fatih-ITS is offline   Reply With Quote
Old   December 17, 2014, 07:46
ghost82's Avatar
Rick
ghost82 will become famous soon enough
As suggested above rsm turbulence model is the most appropriate.
If you want to switch to k-epsilon I suggest the rng model with the swirl option switched on.
PS: don't be depressed
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
Heat Transfer simulation: No convergence problem fiqs CFX 2 April 21, 2010 15:47
History Convergence: Graphical problem Bedotto Fidelity CFD 1 March 17, 2010 23:40
Convergence problem suthichock Main CFD Forum 27 May 11, 2009 07:05
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 22:18
CONVERGENCE PROBLEM - oil boiler MM FLUENT 1 February 15, 2007 05:24
