December 31, 2014, 05:06 |
absorption & reflection coefficient
mehdi
Rep Power: 11 |
hi everybody
How absorption & reflection coefficient can be applied to walls, because only emissivity can be entered for walls. thanks. mehdi. |
December 31, 2014, 10:48 |
Lucky
Rep Power: 65 |
In general you cannot enter an absorption coefficient for a wall boundary condition because it is not a boundary condition, it is a physical/material property. Reflection is even more complicated because it is bi-directional.
But are you trying to use the surface to surface radiation model? Even if not explicitly, you might be thinking about the prob using the s2s model and applying the gray-diffuse model for thick bodies. In thick body radiation, one can have: emissivity, reflectivity, absorptivity, & transmissitivity. By energy balance the sum of reflectivity, absorptivity, & transmissivity must be 1. If the surface is opaque and thick enough, you can eliminate transmissivity because all light is absorbed. In thermal equilibrium, Kirchoff's Law gives that absorptivity equals emissivity. Hence, all of these properties are uniquely defined once you know the surface emissivity. |
Soot absorption coefficient in UDF | lei | Fluent UDF and Scheme Programming | 8 | May 23, 2019 04:44 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Problems with absorption coefficient | flotus1 | Fluent UDF and Scheme Programming | 0 | June 29, 2012 02:09 |
Can't set absorption coefficient for inert particle | lauripar | FLUENT | 1 | May 9, 2012 15:09 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
