total pressure(stagnation pressure) is changing in adiabatic nozzle |
December 29, 2014, 05:48 |
Riyaz Ahamed S
Rep Power: 11 |
Hi
I am trying to solve a simple nozzle problem in Ansys FLUENT.In adiabatic nozzles Total temperature,total pressure should be constant.My solution total temperature is remains constant.But total pressure is not constant in particular place.Please see the attached image. stag pressure.jpg 1)can anyone clarify the reason why it is not constant? 2)How to get constant total pressure? Thanks in advance. Details of the problem is given below. Geometry:geometry.jpg Material :co2 constant specific heats, molecular weight=44.01 g/mol density:ideal gas relation. Model: Invicid model Boundry condition: 1)INLETressure inlet=6 bar(gauge),Total temperature=427K 2)OUTLET: -6 bar(gauge) 3) operation pressure is 8 bar. |
December 29, 2014, 14:14 |
Lucky
Rep Power: 65 |
Are you using the pressure based solver or density based solver?
edit* nevermind, I see the screenshot that says dbns |
December 29, 2014, 22:23 |
Riyaz Ahamed S
Rep Power: 11 |
I have used density based solver.
December 29, 2014, 22:24 |
Riyaz Ahamed S
Rep Power: 11 |
December 31, 2014, 23:34 |
#5 | |
Riyaz Ahamed S
Rep Power: 11 |
January 1, 2015, 02:37 |
Amin
Rep Power: 14 |
hey
does happen any oblique or normal shock in the nozzle? can you attach mach number and pressure contours!? |
January 1, 2015, 23:12 |
Riyaz Ahamed S
Rep Power: 11 |
For the same above mentioned problem, I have changed the mesh to more fine.Here I have attached the results (plots,contour)...
1.Total pressure along the axistotal pressure.jpg 2.Mach no along the axis mach no.jpg 3.Pressure along the axis static pressure.jpg 4.Mach no contourmach no cont.jpg 5.Pressure contourpressure cont.jpg |
Pressure Driven Supersonic Flow in Converging-Diverging Nozzle | cdm | OpenFOAM Running, Solving & CFD | 7 | August 28, 2019 01:37 |
static vs. total pressure | auf dem feld | FLUENT | 17 | February 26, 2016 13:04 |
changing the coefficients of pressure correction | Noel | Phoenics | 1 | April 7, 2009 08:54 |
Total pressure to static pressure ratio | roadracer | Siemens | 1 | April 17, 2003 05:31 |
Total pressure in real gas (compressible flow) | Bart Prast | Main CFD Forum | 3 | November 14, 2000 10:44 |
