January 27, 2015, 20:57 |
Using UDF in fuel cell addon module
Brian
Rep Power: 11 |
Hi I'm using PEM fuel cell addon module in fluent.
I'm tring to model the micro porous layer to a unit cell. But in the fuel cell module, I can give only one porocity and one contact angle to the porous cell zone. So I need to change boundary conditions in the porous media. then I should use UDF macro to give boundary conditions. so I got in to the pem_user.c file and found DEFINE_DIFFUSIVITY(diff,c,t,j_spe) { return pem_diff(c,t,j_spe); } and in the pem.h file, real pem_diff(cell_t c, Thread *t, int j_spe); My questions are, 1. Is there no way to see the contents of pem_diff(c,t,j_spe) ? 2. How can I use UDF Macro in the fuel cell addon module? 3. Can you give me a advise about modeling extra layer of porous media? |
February 11, 2015, 14:17 |
fuel cell module addon_code
walied
Rep Power: 11 |
hi, dear
to see the content of the addon code of fuel cell please follow the directories "C:\Program Files\ANSYS Inc\v145\fluent\fluent14.5.0\addons" you can make change to the pem code and do the recompilation again. see the attached pdf file for more datails. |
February 11, 2015, 22:33 |
Brian
Rep Power: 11 |
Hi walied123 thanks for your reply.
yes I know Ansys provides user-accessable-functions in pem_user.c file in addons/src folder as you mentioned. I want to see and change the contents of UDF of source terms and charge transfer conservation. In the C-file, I couldn't find any content of them. please help me |
February 12, 2015, 02:55 |
#4 | |
Rep Power: 11 |
If you want to see the equations how these source terms are calculated by default..check the fuel cell manual..it is given over there...
February 12, 2015, 03:18 |
Brian
Rep Power: 11 |
Thanks again maverick.
I've checked out the fuel cell manual. It was a lot of help. How can I see the c-code of default source terms and UDS flux, UDS diffusion? Are they not opened to see? There are only declare exression in C file and I can't find the C-code contents of those UDS function. |
February 12, 2015, 03:25 |
#6 | |
Rep Power: 11 |
I think, you can not see it as it is not available for Users. But you can modify it for sure with your code/equations.
fuel cell, module, udf |
Setting cell variable values in a fluid zone using UDF | eromon84 | Fluent UDF and Scheme Programming | 6 | March 28, 2021 11:59 |
Identifying cell in parallel UDF | upeksa | Fluent UDF and Scheme Programming | 0 | July 24, 2013 11:27 |
UDF for heat source on surface instead of the whole cell zone?? | benson621 | Fluent UDF and Scheme Programming | 4 | December 8, 2011 11:54 |
Fuel Cell Module Tutorial Mesh File. | PEM_Fuel_Cell | Main CFD Forum | 1 | September 13, 2006 16:11 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
