Solving with FLUENT in a reduced domain
Old   February 2, 2015, 06:18
Lightbulb Solving with FLUENT in a reduced domain
manalis is on a distinguished road
Does anyone know if it is possible to solve with FLUENT a part (which is changing dynamically) of your domain and not the full one? Could this be possible with a UDF? I was thinking about this option as I have melting/solidification problem that I am dealing with and it could be helpful to be able to solve only the fluid domain and a small part of the solid, thus avoiding the time-consuming solution of the full domain.
Thanks in advance.
manalis is offline   Reply With Quote
Old   February 20, 2015, 03:42
Any thought or idea is welcome!
Old   February 20, 2015, 05:10
Cees Haringa
CeesH is on a distinguished road
Hi
I think you need to be a little bit more clear on what you want, but in many cases the answer is yes:
1) if the domain is periodic, you can use this and only solve one periodic section of the domain.
2) if you are interested at looking at a small part of the domain, while keeping the rest constant, just make a geometry of the specific part and impose the proper boundary conditions (if they are complex or transient, use a UDF for your boundary conditions)
3) there are options for combined RANS/LES if you mean you want to solve one part of the domain with significantly more detail than the other
But as mentioned, I'm not sure if any of these things is what you want?
CeesH is offline   Reply With Quote
Old   February 24, 2015, 03:47
Originally Posted by CeesH View Post
Hi
To be more specific, I would add these: The domain isn't periodic. It is a closed circular cavity (2D), where an initially solid material is being heated and it is gradually melting. The flow is laminar, so I don't use any turbulence models.
The unusual thing in this case is that when you are using the melting/solidification model, your fluid domain changes dynamically (it has been transformed to fluid from solid) but you cannot know in advance which will be the new fluid "part". There is a criterion to figure out solid from liquid, it is a variable called "liquid fraction". So, actually my question is if it is possible through a UDF to solve every time only the domain (from previous timestep) that has the required value (in this case "liquid fraction" = 1).
I hope that I made it a bit more clear than before. Thank you very much for your help anyway.
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
Problems with simulating TurbFOAM barath.ezhilan OpenFOAM 13 July 16, 2009 05:55
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
