Inlet BC for turbulent flows
Old   February 3, 2015, 07:27
Default Inlet BC for turbulent flows
Anonymous
marauder is on a distinguished road
Normally when I do turbulence problems my practice was to give the Turbulence Intensity & Hydraulic diameter.
But now as I was doing a problem where flow enters in to a cylinder tangentially at four different points on circumference I was not sure if fluent was correctly predicting the flow pattern so I changed the above to Intensity and Viscosity Ratio & kept the deafult values of 10%. This seems to capture the flow better as expected.
Can anybody please suggest what kind of inlet BC I should use for turbulent case like this??
Thanks.
marauder is offline   Reply With Quote
TimeVaryingMappedFixedValue for Direct Numerical Simulation inlet johndeas OpenFOAM 5 May 21, 2014 07:11
"Closing" a pressure inlet via UDF? dave88 Fluent UDF and Scheme Programming 0 August 27, 2013 18:14
[swak4Foam] Trouble setting groovyBC interFoam Inlet BC mgdenno OpenFOAM Community Contributions 4 July 1, 2012 08:16
[TGrid] Inlet passage in turbogrid. soldimix15 ANSYS Meshing & Geometry 0 September 5, 2010 11:34
Diffusion component at inlet Balaji FLUENT 2 August 8, 2005 07:37
