Home > Forums > FLUENT
Aerodynamic 3D Wing simulation
Old   February 7, 2015, 15:23
Default Aerodynamic 3D Wing simulation
aleix de toro diaz
aleix.de.toro is on a distinguished road
Hi friends!
I am studying a 3D wing (NACA 0012 0.5 meters span 1 meter chord) on ansys fluent, but I am having some problems. The mesh has over 1.6 millions elements, the skewness is 0.89 and ten maximum aspect ratio is 32. You can see the attached mesh. Maybe the skewness is a little bit high, but I think aspect ratio is pretty good. I have include an inflation layer too.
On fluent, I am using a density based solver with Spallart Allarmas. The inlet velocity is 30 m/s at 10 angle of attack (yes I have introduced the correct x and z velocity projections for boundary inlet conditions). The references values are introduced too, the area of the wing (on the lift Z projection 0.5*1=0.5 m^2) as well as the chord 1 meter. On Solution monitors, I have added lift and drag coefficients with its proper projections for 10 angle of attack. Then I have initialized and calculated the solution.
The proper value of lift coefficient for 10 degrees of a NACA0012 is 1, and drag coefficient is 0.012 (http://turbmodels.larc.nasa.gov/naca0012_val_sa.html)
On my lift coefficient attached picture, the result of lift coefficient is 0.17 which has no sense. The drag coefficient is more accurate (0.036), but not perfect.
I could have let the computer rune more time, but the lift coefficient would not have differ more.
Has anyone of you tried to simulate a 3d naca 0012 and obtained proper results? Or what am I doing wrong :SS
Many thanks!!!!
aleix.de.toro is offline   Reply With Quote
Old   February 7, 2015, 16:18
ghost82's Avatar
Daniele
ghost82 will become famous soon enough
Hi!
I'm not expert with wings, but as I can see from your pictures your scaled residuals are too high.
I suspect your solution is not converged and this can derive from different reasons..you can try to improve the mesh, can't you generate a full hexa mesh?
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
Old   February 8, 2015, 06:43
aleix de toro diaz
Do you mean mesh methods and hex-dominant method?
I have tried but it appears some error. :/
Old   February 8, 2015, 07:23
ghost82's Avatar
Daniele
I don't use ansys meshing, but I mean a mesh with hexa elements in all domain.
Usually it provides better results and better convergence.
Old   February 8, 2015, 10:41
aleix de toro diaz
Yes thank you I have tried, but im not having good results. Thankyou anyway!
Thread Tools
Trackbacks are On
Bird Wing simulation suggestions c0sk OpenFOAM 19 February 2, 2014 14:29
flapping wing simulation in fluent Carlen Fluent UDF and Scheme Programming 0 July 24, 2012 21:37
Pitching Wing simulation rieuk OpenFOAM 5 March 21, 2010 04:12
LES of wing... ned help mariachi FLUENT 9 January 19, 2010 12:55
Setting up Flow around a Wing Simulation help Atella CFX 3 January 3, 2010 12:51
