Gambit Startup Window
Old   July 27, 2006, 03:03
Default Gambit Startup Window
Jay Shim
Hello, everyone. I'm having trouble with the Gambit startup window. Actually, I want to use the gambit as a batch process (using the journal file), and after the gambit run, the control does not come back to command prompt due to this Gambit startup window (small window which you get when you first launches the gambit by GUI). As a result, I cannot process the next batch job automatically. (I always need to click the "close" button manually on this window) Does anyone know how to setup the gambit so that this startup window does not appear?
Old   September 17, 2010, 03:15
Jorge Muņoz
L3munoz is on a distinguished road
Does anyone know how to do it?? I was also interested on running gambit using a journal file and closing this startup window will be necessary, so if anyone has any idea, it's welcome!!
L3munoz.
L3munoz is offline   Reply With Quote
Old   February 12, 2015, 14:05
Default Help me
phdcandidate is on a distinguished road
Originally Posted by Jay Shim
;134546
I have the same problem as you. I would be pleased if u would let me know if u find any solution to ur problem?
phdcandidate is offline   Reply With Quote
[GAMBIT] auto close Gambit window MEDI ANSYS Meshing & Geometry 1 September 3, 2010 06:18
Gambit 2.3.16 startup error tahakhot ANSYS Meshing & Geometry 0 April 24, 2009 15:20
Gambit startup options PAD FLUENT 0 July 21, 2006 05:38
Startup Problem in Gambit 2.2 with WindowXP Win Win Maw FLUENT 3 January 25, 2006 11:09
Gambit startup error: libXp.so.6 cannot be found Patrice Guay FLUENT 5 August 10, 2005 13:03
