Transient udf for limiting flux (solid fuel combustion)
Hi everyone,
My name is Bharadwaj B S, I am currently doing a project on solid fuel combustion (Single particle). In this I have created a sphere inside a cylindrical fluid domain. There will be velocity inlet from one side of cylinder and another inlet from the surface of the sphere as mass flux( kg/m^2 s) signifying volatile release. I have written a simple code where the flux from the sphere is arbitrarily dependent on sphere face temperature (F_T(f, t)). Upto 20 seconds there should be mass flux from the surface of the sphere, when the time reaches 20 seconds the mass flux from surface should stop. For this I have used the if else condition. From the logic side it seems to be fine. But when I hook and see the result. It is not showing the flux from the surface. QUESTION: 1. Is there any mistake in UDF (macro used, logic or anything)? 2. Can I use CURRENT_TIME in DEFINE_PROFILE? Because there is a separate macro for transient Profiles. (DEINE_TRANSIENT_PROFILE). 3. Is there any correction in condition (if (time <= 20))?? Please reply at your earliest convenience. Any help will be of great use for me. Thanks in Advance.:) UDF: #include "udf.h" #include "math.h" real time; real tmp; real flx; real a; real b; int i; int ID = 13; Thread *t; face_t f; cell_t c; DEFINE_PROFILE(flux, t, i) { Domain *d; d = Get_Domain(1); t = Lookup_Thread(d, ID); flx = 0.0; tmp = 0.0; a = - 0.5; b = 0.0; time = CURRENT_TIME; begin_f_loop(f, t) { if(time <= 20) { flx = - a * tmp; tmp = F_T(f, t); F_PROFILE(f, t, i) = flx; } else { F_PROFILE(f, t, i) = b; } end_f_loop(f,t) } } |
