thermal boundary condition on an interface between a solid and a fluid |
February 24, 2015, 12:05 |
ajdad
Rep Power: 11 |
I am modeling an interface between a fluid and solid and in ANSYS FLUENT I get a wall and its shadow. I want to specify a heat flux on the wall but it looks like when I do that the heat flux is not conducted to the other wall. ??? please, help me ... |
February 25, 2015, 17:52 |
Lucky
Rep Power: 65 |
Check to make sure the thermal boundary condition on the other wall and make sure it is the coupled condition. I think by default it's 0 heat flux.
February 25, 2015, 18:29 |
ajdad
Rep Power: 11 |
thank you LuckyTran. but in ansys fluent, we can not choose the two options at the same time: coupling the two faces and impose a boundary condition :-(
February 26, 2015, 16:28 |
JSM
Rep Power: 20 |
Once you select heat flux or temperature option instead of coupled, there won't be any heat transfer between these walls. You are decoupling the walls. Why you want to fix the temperature in the wall of inside domain? I don't understand the specific reason for this question. There are many ways we can model this. 1. Remove solid and apply heat flux on the wall directly 2. Separate one layer element from solid nearer to the fluid and define as another solid and give the source term. 3. Use shell conduction option in the wall boundary condition and define the heat generation. Select the one which is more suitable for your simulation definiton.
With regards, JSM |
February 26, 2015, 21:44 |
ajdad
Rep Power: 11 |
thank you mr jsm for your response. ok, if I want to use 3rd choices:
"Use shell conduction option in the wall boundary condition and define the heat generation." How to convert a thermal power w/m^2 ==> W/m^3 ??? |
February 28, 2015, 10:20 |
JSM
Rep Power: 20 |
It is difficult to answer your question. Usually, We have energy in Watts and that is the input as heat flux (W/m2) or energy source (W/m3).
With regards, JSM |
June 5, 2015, 04:41 |
i have a question
DENG Weriping
Rep Power: 10 |
Hi,everybody. I have a question about heat flux: how can i get the heat flux of a line?
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
