Home > Forums > FLUENT
x, y, z coordinates in automatic solution data export
Old   March 9, 2015, 01:06
Default x, y, z coordinates in automatic solution data export
Jacob
ImolaSpa is on a distinguished road
Hello all...
I have setup a solution data auto-export to look at a few quantities such as x-velocity and y-velocity on a specific surface. I have also selected the x, y, and z coordinates because I need to know the location of the data points. When I do this, I get the following columns of data (written exactly as they appear in the data file):
1. cellnumber
2. xcoordinate
3. ycoordinate
4. zcoordinate
5. dexvelocity
6. tyyvelocity
7. tyxcoordinate
8. teycoordinate
9. tezcoordinate
So columns 1-4 appear no matter what quantities I select. 7-9 are there because I have selected x, y, and z coordinates under quantities. (I am using ASCII cell centered for the export and the model is 3D with a structured hexa mesh)
My problem is that the coordinate data does not match (ie the x coordinates are not the same in column 2 and 7...close but not exactly the same). Does anyone know which set of data I should be using to get the correct location of the cells?
Thanks in advance!!
-jacob
ImolaSpa is offline   Reply With Quote
Thread Tools
Trackbacks are On
how to export every data w.r.t time to txt file jaho CFX 94 August 25, 2015 09:45
Unable to install OpenFOAM 1.6-ext Maimouna OpenFOAM Installation 23 May 8, 2014 05:47
Easy way to export monitor data from CFX out file jonny_b CFX 24 October 23, 2013 17:13
Neumann Boundary Condition for Poisson Equation solution in Polar Coordinates prapanj Main CFD Forum 2 July 30, 2011 19:07
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
