March 18, 2015, 07:43 |
Natural Convection in a vertical duct
Alireza Safikhani
Rep Power: 15 |
Dear guys,
I want to simulate natural convection in a vertical duct to calculate the hot air mass flow rate which is suctioned from duct (attached figure). In fact I do not kniw which boundary condition should be used in inlet and outlet. If I use wall then the mass flow is zero and if I use velocity or mass flow inlet I have not value for them. Please help me. Sincerely |
March 18, 2015, 11:32 |
Haroon Junaidi
Rep Power: 11 |
You can use Pressure inlet and pressure outlet and keep the pressure the same at either end i.e. zero.
March 18, 2015, 11:51 |
Rick
Rep Power: 26 |
It's not simple to set boundary conditions in this case.
I know that one of the methods is to extend the domain, so that boundary conditions will not affect too much the flow in the channel. You can try to read this, maybe you will find what you are searching: https://tel.archives-ouvertes.fr/hal-00841302/document
Google is your friend and the same for the search button! |
natural convection in vertical channel | Arjun123 | FLUENT | 11 | November 23, 2014 09:09 |
Specifying turbulence parameters for natural convection on vertical flat plate | abu250feldman | FloEFD, FloWorks & FloTHERM | 2 | May 5, 2014 13:42 |
natural convection in a vertical tube | are_if | Main CFD Forum | 0 | January 30, 2012 08:22 |
Airpak: natural convection in a duct | NeOmega | FLUENT | 2 | August 27, 2004 13:28 |
natural convection in a vertical heated duct. | SHANTANU CHAKRABORTY | Phoenics | 1 | June 18, 2001 09:12 |
