March 23, 2015, 11:00 |
How to turn off pressure strain term?
Pablo Cornejo
Rep Power: 11 |
Hi all,
Need to know if it is possible to turn off the pressure strain term in the Reynolds Stress turbulence model. Cya |
March 23, 2015, 12:03 |
kai
Rep Power: 12 |
Why do you want to turn off the pressure strain term? To do so, i think you could add a (-pressure strain term) into Source term of momentum equation? But pressure strain term is so important when you use RSM model. |
March 23, 2015, 13:15 |
Pablo Cornejo
Rep Power: 11 |
I'm interested in the turbulent energy redistribution between the normal components caused by pressure fluctuations. That way i need to simulate the same configuration with and without including the pressure strain term.
March 23, 2015, 13:31 |
kai
Rep Power: 12 |
Then you must have a 3D case with large pressure gradient say swirl? Otherwise it will not really show much difference using RSM or two equations models.
March 23, 2015, 13:33 |
Pablo Cornejo
Rep Power: 11 |
obviously.
So do you have another straightforward way to do it? |
March 24, 2015, 08:21 |
kai
Rep Power: 12 |
No, that's the only way i can think of..
Application of a pressure gradient/forcing term in a compressible pipe flow | mrs206 | OpenFOAM | 1 | July 14, 2017 12:36 |
Setting up the pressure variation due to tornado in a duct(UDF)+animation | guillaume1990 | FLUENT | 0 | March 3, 2014 11:59 |
Static vs dynamic pressure in Reynolds stress source term | natrask | OpenFOAM Programming & Development | 0 | August 13, 2010 14:45 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
