Time/Iteration and Time to Convergence FLUENT |
March 26, 2015, 20:59 |
Rep Power: 11 |
I am working with ANSYS FLUENT and am trying to figure out the time per iteration for my solution. Does anyone know where I can find that information?
I see in the printout that there is a column titled time/iter. Is this the time per iteration? if so it doesnt make sense because I get a read out of something linke 00:22:48. I am assuming this is in hh:mm:ss format and I am doing 2D with only 55k elements so my iterations do not take 22 minutes each. Alternatively I was wondering if it might be time remaining and number of iterations remaining. Does anyone know if this is the case? I really would just like to know how long the solution takes, the time per iteration and, if it is possible, the total memory used. Does anyone know how to do this? Any help is greatly appreciated. |
March 26, 2015, 22:17 |
Lucky
Rep Power: 65 |
The printout is the estimated time needed to complete the remaining iterations (time remaining & iterations remaining).
March 26, 2015, 23:07 |
Rep Power: 11 |
Thank you LuckyTran. Do you if I can print the actual time for the solution to converge and how much memory was used for the selected solution settings?
March 30, 2015, 03:02 |
Rep Power: 18 |
The wall-clock time and CPU time can be found via Parallel > Timer > Usage. The memory usage can be found via Mesh > Info > Memory Usage.
March 30, 2015, 10:16 |
Rep Power: 11 |
fluent, solution time, time per iteration |
How to determine time step size and Max. iterations per time step. | pratik c | FLUENT | 46 | January 21, 2024 12:21 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
