Superimposing a developed Velocity Profile at a different plane |
March 30, 2015, 16:00 |
Hassan Iftekhar
Rep Power: 11 |
I want to superimpose a developed velocity profile at the inlet of a small model. The velocity profile is at a distance 227 mm from the inlet. I want to extract that velocity profile and give it at the inlet of a small model How this is possible? Please share easy method. Regards, Hassan |
March 30, 2015, 16:04 |
Rep Power: 18 |
What is the geometry of your inlet? How are you currently imposing the velocity inlet condition? If it's pipe flow, then you could use the analytic solution.
March 30, 2015, 16:18 |
Hassan Iftekhar
Rep Power: 11 |
Thanks for your reply.
Geometry = rectangular duct I am using average velocity of 0.5 m/s at the inlet. |
March 30, 2015, 16:49 |
Rep Power: 18 |
Are you modelling 2D or 3D?
A long winded approach:
Computational approach: increase the geometry to allow the flow to become fully developed. Quick approach: read the section on "Reading and Writing Profile Files" in Fluent's user guide. |
March 30, 2015, 17:12 |
#5 | |
Hassan Iftekhar
Rep Power: 11 |
How to extact points from the surface. Can you explain point 3. Which format? and how to apply the velocities in fluent. Thanks once again. |
March 30, 2015, 18:22 |
Rep Power: 18 |
If your model doesn't change in width or height (dimensions which would alter the inlet boundary dimensions) then this task is trivial. Does your 3D model of the duct include any other features blocking/affecting the flow, or is the outlet simply a developed profile? If your geometry is a simple duct, then use my "quick approach" above.
March 30, 2015, 18:35 |
Hassan Iftekhar
Rep Power: 11 |
There is a step (obstruction) in between the channel... it is a developed velocity profile.
But I dont know how to extract points from a surface. |
March 30, 2015, 19:09 |
Rep Power: 18 |
It appears you're trying to model flow over a step. Why are you trying to reduce the entrance length in the first place? The computational requirements are negligible for including an entrance length as your mesh is coarse in this region.
I assume (from your mesh) that you're new to CFD and suggest you have a read of this tutorial on modelling a sudden expansion in laminar pipe flow. |
March 30, 2015, 19:47 |
#9 |
Hassan Iftekhar
Rep Power: 11 |
My flow is turbulent. The idea behind generating a coarse mesh is to save computational time. I have generated a fine mesh at step to capture the reattachment length...
I still want to go more fine at other regions (away from step-near outlet) as I want to extract data at various locations downstream. First I am trying to capture reattachment length. I have reduced entrance length to save computational power. My entrance length was 1200 mm. It takes around 25-30 D to develop mean velocity profiles. where D is hydraulic diameter of duct. I have reduced it to 240 mm |
Udf for a fully developed velocity profile atinlet | philip meppen | Fluent UDF and Scheme Programming | 10 | November 3, 2015 15:56 |
Velocity profile boundary condition | Tuca | FLOW-3D | 1 | April 23, 2013 12:02 |
How to apply an outlet velocity profile to another inlet? | siw | FLUENT | 4 | April 10, 2013 11:19 |
How to prescribe fully developed turbulent velocity profile at inlet? | nore5 | OpenFOAM Running, Solving & CFD | 1 | February 22, 2013 09:30 |
Logarithmic velocity profile | cfdworker | Fluent UDF and Scheme Programming | 0 | April 23, 2009 19:09 |
