negative volume ..,mesh update failed
Old   April 15, 2015, 04:59
Question negative volume ..,mesh update failed
logan
wolverine is on a distinguished road
i have been encountering this pbm . my case is a sinusoidal accelerated boundary wall .. is there any specific criteria to enhance the meshing ?
wolverine is offline   Reply With Quote
Old   April 15, 2015, 07:04
Marc Pelegri
pumpkin is on a distinguished road
Try setting a really small time step, so that the mesh does not move more than a single cell.
pumpkin is offline   Reply With Quote
Old   April 15, 2015, 10:23
logan
i tried lower time steps.. will mesh morphing helps??
Old   April 16, 2015, 04:08
Marc Pelegri
I'm not sure mesh morphing will help.
I suggest you to check where are your negative volumes. Try doing a plot of volume (with different iso-values).
Then check if there are some left-handed cells. If so, I think you can repair them with in the command line with /grid/modify-zones/repair-face-handedness
Hope this helps.
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 03:35
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 05:25
Negative Volume during Mesh Motion Analysis giov_ingr FLUENT 2 December 13, 2013 06:09
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
Help: Negative Volume MANOJKUMAR FLUENT 8 December 24, 2005 04:59
