Vortex Breakdown
Like Tree2Likes
  • 1 Post By thomasmilin321
Old   April 3, 2015, 13:52
Lightbulb Vortex Breakdown
Thomas Milin
thomasmilin321 is on a distinguished road
Respected Users,
I am doing a simulation of the vortex breakdown phenomena in an open cylinder(top) with rotating bottom wall. I am using water as the fluid and the bottom is rotated at Re=2600 as per the journal. The top is open to the atmosphere. At Re=2600 I am getting the exact replica of the vector plot but as the Reynolds number is increased I am not able to obtain the vortex breakdown phenomena. Breakdown was obtained in the journal at Re=3000. Following are the input parameters i am giving in fluent.
Solver- Pressure based ,steady, relative
Models- Laminar(all others off)
Materials- water (from database)
Cell zone condition- interior volume is made fluid and material is made water.The rotation axis origin is given as (0,0,0) and rotation axis direction as (0,0,1)(all other boxes are left unchecked)
Boundary conditions-
top is made pressure inlet
bottom is made rotating by imparting angular velocity(by selecting moving,rotational,absolute) of .104667rad/s.
radius is 15.23cm and height is 63.19cm
side is made a no slip wall
Reference values- compute from bottom is given and reference values are left as such, reference zone is selected as interior volume
Solution methods- simple, least square cell based, second order, second order upwind
Solution controls- under relaxation factors are retained as such(i.e pressure .3, body forces 1, density 1, momentum .7)
Standard absolute initialization is given
These are the various input parameters I am giving yet i am not able to obtain the breakdown phenomena.
Any comments will be really valuable.
Thanking you for your patience and help.
P.S] I am also enclosing the velocity contour plot of my simulation at Re=2600
anon_h likes this.
thomasmilin321 is offline   Reply With Quote
Old   April 6, 2015, 00:36
Thomas Milin
Thank you very much for your suggestions . Let me make a simulation with your suggestions and ill post the result.
Yes i think so. Consider the case of shock waves generated when the valve of a penstock pipe is closed.
Old   April 16, 2015, 04:55
Thomas Milin
The transient mode you specified is also not yielding any vortex breakdown phenomenon. It is also giving the exact same result as i used to get with previous cases. Do you have any other alternatives for the problem.
Thank You
Vortex breakdown thomasmilin321 ANSYS 1 October 13, 2014 12:23
Presenation of vortex strength and velocity concept? fruitkiwi Main CFD Forum 0 September 26, 2012 22:08
Vortex breakdown thecfduser Main CFD Forum 0 July 10, 2010 02:47
vortex breakdown daniel Main CFD Forum 13 February 19, 2004 10:25
Vortex Breakdown / Diffuser Performance Olu Main CFD Forum 1 November 11, 1998 12:49
