fluent wants to overwrite report file to continue |
April 17, 2021, 03:42 |
mody
Rep Power: 5 |
hello i live in a third world country where electricity goes out for a few minutes everyday. the problem is when i open the fluent to continue the case it asks to overwrite the report files .
for example if the saved report was from 0s to 2000s before power shutdown. when i try to continue ,it write in the report file starting from to 2001 and deletes the previous 2000s.this forces me to back up old file in another folder before continue running . is there a way so it continues without removing the old 2000s ? |
April 17, 2021, 04:34 |
mody
Rep Power: 5 |
i would be glad if someone could help
April 17, 2021, 19:05 |
Lucky
Rep Power: 65 |
If you choose to not overwrite (answer no) it will append. Problem is, now you might have duplicate data.
For example if you run and your simulation stopped at time-step 1251 but you backed it up at 1000. Now you rerun starting from 1000, your file will contain data from timesteps 0-1251 and then start again from 1000 onwards. But if your simulation stops at 2000 and you restart it from there, it shouldn't be an issue. |
fluent, report, report definition, report file, shutdown |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 35 | April 29, 2022 15:35 |
[swak4Foam] Installation Problem with OF 6 version | Aurel | OpenFOAM Community Contributions | 14 | November 18, 2020 16:18 |
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 01:22 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
