swept back wing: how and which boundary conditions to use in Fluent?
Old   March 12, 2015, 09:47
Default swept back wing: how and which boundary conditions to use in Fluent?
Mary Claire
Silver Silhouette is on a distinguished road
hey ppl
i am currently doing a project on static and dynamic stability of a swept back wing. So far i have created the wing in Solidworks,exported it to ansys fluent and meshed it. What I am confused with is the next step. Can you tell me the exact boundary conditions to give in fluent?
I would like to find out Cl , Cd and pressure distributions at different angle of attacks
Thanx
Silver Silhouette is offline   Reply With Quote
Old   March 12, 2015, 10:38
anonymous
sjbub is on a distinguished road
I would take some time to read the fluent ansys user and theory manual. Also do some general internet searching I bet you can find a handful of papers that give their boundary condition details. Here is one that popped up on the first search.
http://www.ripublication.com/aasa/aasav3n3spl_02.pdf
sjbub is offline   Reply With Quote
Old   March 15, 2015, 04:33
Default thanx a lot for that ...it was very helpful :)
Mary Claire
as i am new to this...i may ask some weird questions..dont mind
after i run iterations for a certain number of times and close it ..i am not able to view the graphs again after opening it
Old   March 15, 2015, 04:39
Default angle of attack
Mary Claire
also can you tell me how to plot graph between for pressure distribution when you are varying angle of attack and velocity
Old   April 5, 2015, 13:58
Default operating pressure
Mary Claire
hi
i am doing an analysis over an aircraft wing in fluent with a mach no 0.785 and would like to know the operating conditions as well as guage pressure to be used in the boundary conditions
Old   April 5, 2015, 18:09
Mahdi
metmet is on a distinguished road
hi
Hi
For first question You need to save both case and data of your solution and for next time you should open the *.cas and after that load the *.dat file to check your results.
For second question for each velocity or AOA go to reports and print pressure distribution on your desired boundary condition ( in this case surfaces of wing), now save the value in a spread sheet and repeat the work for all velocities and AoAs and finally plot them.
My suggestion is to read Ansys fluent theory guide and tutorial guide to make the job easier. Found this quickly:
http://www.cfd-online.com/Forums/flu...tml#post481127
metmet is offline   Reply With Quote
Old   April 10, 2015, 13:42
Mary Claire
thankyou so much for the help...it was very effective
Old   April 10, 2015, 13:50
Default FSI analysis
Mary Claire
i have got a small doubt in FSI analysis..i made my wing and put a rectangular domain region over it..i ran the flow analysis over it and found out pressure distribution over the wing.this pressure i imported to static structural analysis.i then clicked the root of the wing as my fixed support and ran deformation analysis. i think i got the results but the problem is i cant view the wing alone.. it is coming along with the rectangular boundary region.
how can i view the deformation on the wing alone?
i ll attach some files for reference
thanx in advance
