Negative volume in internal combustion engine analysis |
August 16, 2012, 16:40 |
Ahmet
Rep Power: 15 |
I m trying to make an internal combustion engine analysis in fluent. I have set dynamic mesh zones.when displaying zone motion, it looks like ok. But when I Preview mesh motion, It gives this error and makes negative volume. What can I do to fix this problem? I realized that it is about cylinder motion. But I could not find the solution. "Warning: Mesh projection of deforming dynamic zones exceeds reasonable limits. Please verify that the correct geometry definitions have been specified. " |
August 18, 2012, 08:38 |
Ahmet
Rep Power: 15 |
I have found that my deforming and stationary surfaces are not matching. Can I measure an edge lenght or diameter in fluent?
April 12, 2015, 15:40 |
Rep Power: 11 |
hello!
I am having the same problem right now also! did u find any solution for that? |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Meshing Structure for Internal Combustion Engine | Majid | FLUENT | 1 | January 1, 2010 15:56 |
negative volume encountered | Maga | CFX | 2 | October 7, 2009 17:31 |
CFD simulation in Internal Combustion Engine | Anne | Main CFD Forum | 17 | May 5, 2005 05:06 |
internal combustion engine port flow simulation | Nyquist | Siemens | 1 | April 29, 2003 03:48 |
