April 12, 2015, 08:02 |
Calculate fill time
Jay
I have a model of a valve in solidworks that is used at work.
The flow through the valve is choked. The valve is then required to fill up a vessel of a set size within a certain time period. The valve has two paths, one of which closes when a certain pressure is reached. I want to be able to put the model into fluent, run the analysis and predict the time taken to fill the vessel to 3.7 bar. The initial pressure is 7 bar and the 1st path closes at 0.7 bar. I have tried to run it as a transient analysis but this it doesn't complete the calculation. Any ideas? |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 09:08 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
