Home > Forums > FLUENT
FLUENT Q-Criterion
Old   April 12, 2015, 09:03
Default FLUENT Q-Criterion
Jacob
smartsoldier is on a distinguished road
I am currently running some LES on an Ahmed Body and pulling out iso-contours of Q-criterion for vortex analysis. However, I would eventually like to move on and stop using LES in favor of a turbulence model. The problem is that when I switch from LES, Fluent no longer calculates Q-criterion for me, as in I cannot select it when I go to export or output my data. Unfortunately, Q-criterion is much more complicated than say Vorticity and cannot simply be calculated as such. Does anyone know how to get Fluent to give me Q-criterion?
smartsoldier is offline   Reply With Quote
Old   April 12, 2015, 19:15
`e`
`e` is on a distinguished road
If you can't find a Fluent UDF of Q Criterion that someone has already created and posted online then you may need to create your own. Have a read of this post on Lambda-2 (similar to the Q Criterion) because they provide equations and code.
`e` is offline   Reply With Quote
Old   April 13, 2015, 04:49
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enough
You can find a custom field function for Q here:
http://www.cfd-online.com/Forums/blo...nt-part-1.html
sbaffini is offline   Reply With Quote
Old   April 14, 2015, 11:15
Jacob
This is exactly what I wanted, thank you so much!
Thread Tools
Trackbacks are On
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 5 September 25, 2013 04:40
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 4 September 20, 2013 16:30
[ANSYS Meshing] fluent cutcell grid and skeweness criterion laxwendrofzx9r ANSYS Meshing & Geometry 4 June 3, 2012 11:45
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 03:57
