Point monitor on the cylinder.
Old   April 12, 2015, 16:02
Question Point monitor on the cylinder.
Jakub
bukajbs is on a distinguished road
I'd like to monitor a point values (static temperature) on the cylinder wall. The cylinder is translated from the 0,0,0 point by known distance. Mesh is structural what means those cylinder walls are hexadecagons in cross-section - not perferct circle as in CAD/geometry files.
Here is my question. If I place monitor point at the basis of geometric coordinates, the point will be automatically 'moved' to the nearby node of the mesh, or somehow it will show the values from the wall?
Important to me is to create those point in Fluent, not in Geometry/Meshing Tools but these sugestions also would be helpfull. The geometry/mesh is quite complicated and selecting those point by 'mouse' is impossible.
Thanks you for help!
Jakub
bukajbs is offline   Reply With Quote
problem in toposet Ahmed Khattab OpenFOAM Pre-Processing 27 March 3, 2023 21:12
Drag force coefficient too high for a flow past a cylinder using komega sst Scabbard OpenFOAM Running, Solving & CFD 37 March 21, 2016 16:16
[blockMesh] error EOF in blockMesh Ahmed Khattab OpenFOAM Meshing & Mesh Conversion 7 May 17, 2012 00:37
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 18:40
