April 13, 2015, 06:21 |
Unsteady Discrete Phase Modeling
Ali Naghi Ghasemi Bidar
Rep Power: 11 |
Hi every body
I am trying to simulating an unsteady discrete phase modeling with a steady main flow. In injector properties I must enter 2 time: start time and stop time,I entered some data for start and stop time bud it did not work ! Can you help me to say what am I doing?? thanks a lot every body! |
April 13, 2015, 06:48 |
Rep Power: 18 |
The start and end times for the DPM injection dictate the time interval this injection has particles injected into the domain (inclusive of the boundaries of this interval). Are you simulating your flow within this time interval?
What is not working, are the particles injected at all? |
April 14, 2015, 02:02 |
Rep Power: 11 |
I consider many different times for start and stop time but it tracked at first and then at next iteration it did not work and run had no good result.
can you help me? |
April 14, 2015, 03:03 |
Rep Power: 18 |
What is your simulation time when your particles are not injecting, and what is your start and stop times for this injection stream?
April 15, 2015, 01:39 |
Rep Power: 11 |
time is not important because I test a lot of start and stop time nut it did not work.
did you simulate unsteady dpm? thanks a lot. |
April 15, 2015, 01:41 |
Rep Power: 11 |
I should point out that my mean flow is steady and dpm is unsteady.
How to go about modeling injection nozzle two phase flow in FLUENT? | skonda2 | Fluent Multiphase | 0 | March 17, 2015 07:52 |
Help with dissolution in Discrete phase modeling | HimanshuSahni | FLUENT | 0 | December 16, 2010 07:38 |
UDF of "anisotropic phase function" in radiation modeling | whiz | Fluent UDF and Scheme Programming | 0 | September 1, 2009 03:26 |
species transport and discrete phase modeling .... | farhath | FLUENT | 2 | February 11, 2006 01:09 |
Discrete Phase Modeling | X.Tang | FLUENT | 0 | April 25, 2000 08:17 |
