Two domains in Fluent
Old   April 16, 2015, 22:52
Default Two domains in Fluent
Devesh
devesh13 is on a distinguished road
Hello All,
I am relatively new to fluent so please pardon my inexperience.
The simplified model which captures the problem of my main problem is like this: There are two domains both have fluid as air. I have two velocity inlets (BC 2m/s) two both domains, and two outlets. The two domains share a interface. and have wall at the opposite side.
I used default parameters and solvers. When the simulations starts the velocity goes haywire, like 4000 m/sec and does not come down with 40k-50k steps.
Surprisingly, when I only have one domain, there is no problem. There is something I am not able to correct/capture for two domains.
Thanks
devesh13 is offline   Reply With Quote
Old   April 18, 2015, 07:22
zhouxman
zhouxman is on a distinguished road
Originally Posted by devesh13 View Post
Hello All,
Thanks
May be the material parameter is not correct, or non physical BC
zhouxman is offline   Reply With Quote
Old   May 8, 2015, 18:15
Devesh
Thanks!!
I found the error was outlet conditions.
The sum of weighting funcition of the two fluids should have been 1, mine was adding upto 2.
Thanks again.
fluent, multiple domain
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 06:22
Interesting problem: Parallel Processor VOF Fluent + Dynamic Mesh + System Coupling spaceprop FLUENT 5 September 2, 2014 09:43
Error in reading Fluent 13 case file in fluent 12 apurv FLUENT 2 July 12, 2013 07:46
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 02:57
