Batch Mode - Linux - Journal file help please |
April 17, 2015, 06:57 |
Hi all
I am trying to simulate a density based solver in a cluster. Can some one help me how to write the journal script with FMG initalization? The one I used before is for Pressure based solver and it goes like: rc "file name" solve/iterate 1000 file/write/data "file name" yes exit What modifications do I need to bring? |
April 17, 2015, 08:31 |
Rep Power: 18 |
These batch files simply follow a series of Text User Interface (TUI) commands that you could execute via the normal Fluent setup. The TUI for defining the pressure based solver is "/define/models/solver pressure-based". You could alternatively modify these settings in the case file before saving and uploading this file.
Note: it's simpler to exclude spaces from your file names, for example: "file-name" instead of "file name". Spaces can cause issues when transferring, amongst other things. |
April 17, 2015, 08:54 |
#3 | |
However it did not work for density based solver because I think I need to initalize and then steer the solution. And when I said ---> rc " file name " it actually meant I put in the real file name of the case. Sorry for the confusion |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
