April 19, 2015, 15:25 |
Reference Temperature in FLUENT
Adnan
Rep Power: 13 |
Hello
I am relatively new to FLUENT. I have a very basic question to ask. I am running a simulation which involves a varying specific heat to incorporate the latent heat. My UDF is as follows: DEFINE_SPECIFIC_HEAT(my_specific_heat, T,Tref,h,yi) { real cp; if (T>1363.) { cp=23550.; } else if (T < 1383.) { cp=23550.; } else { cp=1050; } *h=cp*(T-Tref); return cp; } I wanted to know where I can set the reference temperature? The manual says it can be set in the Materials panel. However, I do not see the option for reference temperature there. Would I have to activate a model so that I can set the reference temperature? Is there any other way I can set it? |
April 20, 2015, 03:20 |
cglr
Rep Power: 11 |
On the fluent interface, there must be a tab "reference values" on the left side. You can change the temperature using that.
April 20, 2015, 10:37 |
Adnan
Rep Power: 13 |
Thanks for the help. I can change the reference temperature.
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
-Xlinker --add-needed -Xlinker --no-as-needed | NH1994 | OpenFOAM Programming & Development | 7 | December 31, 2014 10:24 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 01:27 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
