Computer shut down due to blackout. How can I continue my fluent computation?
Old   April 23, 2015, 21:03
Default Computer shut down due to blackout. How can I continue my fluent computation?
Yetly
yetlyg is on a distinguished road
Hello and good day to all,
I was running a Fluent computation of natural convection flow in a 2-D cylinder, until my computer shut down due to a minor blackout. Is there a way to recover my files or continue the calculation from where it last ended? Or do I just have to initialize again and start over?
I did use the auto save setting (every 1000 time steps).
At this point, I have recovered my mesh and initial setup settings. But it looks as if Fluent won't be able to continue where it last was.
Can anyone please give me any ideas or direction?
Thank you very much.
yetlyg is offline   Reply With Quote
Old   April 24, 2015, 03:39
Cees Haringa
CeesH is on a distinguished road
Autosave should store datafiles somewhere. If you find the latest datafile, you can import that which loads the results from the last autosave. Then, you can work further from the latest autosaved point.
CeesH is offline   Reply With Quote
Old   April 24, 2015, 16:16
nm
nvarma is on a distinguished road
if you had enabled autosave load case, load the lates autosave dat files from the working directory and solve..
otherwise, no..
nvarma is offline   Reply With Quote
Old   April 25, 2015, 04:10
Cees Haringa
Even if you did not enable autosave case, and only autosave data, you can still continue. The datafile should be compatible with your setup casefile.
Old   April 27, 2015, 13:46
Yetly
Thank you CeesH and nvarma. I will upload with your methods.
Computer Requirements for Running Fluent Chaitanya Varma FLUENT 1 February 23, 2007 13:03
A computer to run Fluent - 64 bit? Mike FLUENT 3 September 23, 2005 10:27
fluent 6.2 and computer? sam FLUENT 2 August 28, 2005 02:58
Computer & Fluent tgg FLUENT 4 April 27, 2005 09:32
A computer to run Fluent Mike FLUENT 17 February 4, 2005 11:14
