April 27, 2015, 18:33 |
Divergence when TI of inlet is low
buidu
Rep Power: 12 |
Dear all,
I am running a simulation to study convective heat loss from cylinder. When I set the the boundry of inlet with a turbulent intensity(TI) of 5%, it can converge very well. However, when I set the Ti as 0.1%, the calculation divergeced at around 50 steps. If I want to run a simulation with low TI, e.g. 0.1%, does anyone know how should I set the boundry condition? The calculation domain is in the attachment. Thank you very much. Regards, Hao |
April 27, 2015, 22:03 |
Lucky
Rep Power: 65 |
Are you changing only the TI at the inlet? What about the initialization? The initialization is very important. You need to adjust the value of k, epsilon/omega to better guesses.
April 28, 2015, 04:02 |
#3 | |
buidu
Rep Power: 12 |
Hao |
Display Modes | |
Floating Point Exception Error | nyox | FLUENT | 11 | November 30, 2018 13:31 |
Divergence problem | Smaras | FLUENT | 13 | February 21, 2013 06:03 |
3d vof | Smaras | FLUENT | 2 | February 19, 2013 07:58 |
Low flow rate in channel results in divergence | Purushothama | Siemens | 0 | March 16, 2011 23:23 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
