Convergence criteria based on solution monitoring
Old   May 5, 2015, 06:27
Default Convergence criteria based on solution monitoring
goblin24 is on a distinguished road
Hi all,
i have a question for you...i'd like to know if, in a steady simulation, it's possible (and eventually how) to set Fluent to make it stop automatically when the monitors present flat curves. Maybe in the Convergence Manager?
goblin24 is offline   Reply With Quote
Old   May 6, 2015, 05:23
Paritosh Vasava
vasava will become famous soon enough
These are excerpts from the tutorial titled Fluid Flow and Heat Transfer in a Mixing Elbow. Here the convergence criteria is based on outlet temperature. You can modify according to your own case.
  1. Setup Surface Monitor to observe temperature at the outlet.
  2. Go to Monitors--> Convergence Manager. This will open a window.
  3. Activate convergence criteria based on the Surface Monitor.
  4. Select the termination criteria, how many initial iterations to be ignored and the number of iterations to be considered.
  5. Press ok to close the window.
  6. Initialize the case
  7. Run the case
vasava is offline   Reply With Quote
SIMPLE: no convergence criteria found Gennaro OpenFOAM Programming & Development 3 October 21, 2018 00:08
Setting up additional convergence criteria: output parameters are ‘constant’ Pierre1 CFX 3 March 21, 2015 04:47
Individual convergence criteria for velocity components? CoolHand OpenFOAM Running, Solving & CFD 0 March 3, 2014 16:47
Time step size & convergence absolute criteria yuitsang FLUENT 5 April 15, 2013 04:27
Convergence Criteria in FLUENT mahi007 FLUENT 9 March 1, 2012 06:46
