May 7, 2015, 02:25 |
How to display the blending function in DES
Rep Power: 15 |
Hi everyone,
Recently, I did some simulations based on DES, and I want to know where is the LES region and where is the RANS region. How can I set up the blending function in DES model and display it? Thank you very much. |
June 18, 2015, 10:17 |
Texas
Rep Power: 11 |
blending function is also mentioned in sst model:F1 and F2. i think u can get some idea from there. i am also studying on that.
August 19, 2015, 01:56 |
Rep Power: 15 |
August 19, 2015, 10:26 |
Lucky
Rep Power: 65 |
If you go to contour plot and look at the "surface types", there is an option to plot the rans-les-interface contour. I'm not sure how to export it though. Does this help at all or do you need the actual value of the blending function?
November 17, 2016, 08:08 |
Qiang Zhou
Rep Power: 15 |
Hi,do you have know how to display blending function in Fluent? or other method? Thank you!
June 5, 2023, 09:51 |
Rep Power: 2 |
Hi all,
I'm currently looking into doing exactly this. Did someone managed to do it ? If so how ? Thanks ! |
August 8, 2023, 04:54 |
Rep Power: 2 |
Hi all,
For those interested in this answer, You can do it by adding this in the functions subfield in controlDict: Code:
/*DESModelRegions1 { // Mandatory entries (unmodifiable) type DESModelRegions; libs (fieldFunctionObjects); // Optional entries (runtime modifiable) result DESField; // Optional (inherited) entries writePrecision 8; writeToFile true; region fluid; enabled true; log true; writeControl runTime; writeInterval 0.03; }*/ |
August 8, 2023, 12:41 |
Lucky
Rep Power: 65 |
That's how to do it in OpenFOAM... the question is how to do it in Fluent.
foamToTecplot360 | thomasduerr | OpenFOAM Post-Processing | 121 | June 11, 2021 10:05 |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 01:27 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
