December 5, 2008, 04:36 |
Volume fractions in muliphase model
I am doing a simulation of cavitating flow. I use the pressure based, mixture model with the implemented cavitation model (really just one option of solver if using the cavitation model). The problem thus contains 1.mixture level 2.water (also some non condensable gases defined in the cavitation model) 3.vapor Now i want to implement a UDF for defining my own BC. For this i need the speed of sound of the mixture. i could not access this variable in my UDF C_C2(c,t_mixture) gives the value 0. Anyone has experience with this? to work around this i need to calculate the speed of sound myself. But for this i need each phase volume fraction. Now, i tried C_VOF(c,t_phase_i) does not give the volume fractions. Does anyone have some advice on how to access them? all suggestions and thoughts are welcome |
August 31, 2009, 07:58 |
asif nazir
Rep Power: 16 |
i have also same kind of problem if u have find the solution then plz also inform me about it.specially the problem of finding the volume fraction
May 11, 2015, 07:20 |
federico
Rep Power: 13 |
I have the same problem. Did you find a solution?
Nonphysical volume fractions at multiphase inlet | sylvester | OpenFOAM Running, Solving & CFD | 4 | July 1, 2009 10:52 |
volume fractions in homogeneous flow model? | Matthias Rohner | CFX | 1 | August 26, 2007 18:42 |
vector plot in muliphase? | Tasuio | CFX | 2 | September 29, 2002 07:17 |
Mole fractions from mass fractions? | Keith | Siemens | 5 | September 27, 2002 05:39 |
Higher order for phase volume fractions? | George Bergantz | CFX | 2 | December 11, 2000 11:55 |
