Low orthogonal quality after gradient adaptation
Hi everyone!
I'm running a VOF simulation with water and air. The problem is 2D axisymmetric and the water is going to be falling freely. In order to get a sharp and clean interface I am currently using gradient adaptation (normalized) based on air-fraction (Fluent can't dynamically refine based on water fraction), the mesh is coarsened when the normalized gradient is below 0.1 and refines if it's over 0.1. My problem is that the refined cells automagically turns shitty when refined (orthogonal quality <0.1) which then leads to instability and eventually diverges. Ansys mesher reports a quality of >0.95 in this area. I've tried blocking the mesh by making several smaller connected domains in which I manually set the face size, but I can't make it axisymmetric for some reason. Fluent reports that the mesh is below the x-axis, ansys mesher says it's fine though. Does anybody have an idea on how I can get a clean interface and a stable mesh? And is it possible to do manual blocking of the mesh in Ansys Mesher? Any help would be greatly appreciated! Cheers |
Realized I've been using the wrong tool for the job. If you want to be able to block the mesh (set face sizes manually), you'll need to draw some sketches of your refinement area and the use "face split" to split the face but still keep it as one surface body.
