ANSYS fluent 13: unphysical flow near the outlet, instead of freestream |
May 12, 2015, 10:44 |
Chris
Problem with running a simulation in ANSYS Fluent 13.
Solution is converging perfectly but strange things happen in the velocity profile in the wake region. Strange thing: At the outlet as you may see by looking at the figure below there are some kind of velocity instabilities which to me look very unphysical. What is expected is at the outer boundary the velocity should be again freestream velocity. Suggestions are more than welcome! Boundary conditions: Inlet velocity, Pressure (gage) at the outlet is zero, everything else is wall. Result is from Spalart-Allmaras. EDIT - The run is unsteady and is running for six revolutions of the blades (simulation of a vertical wind turbine). Last edited by NereusC; May 13, 2015 at 07:17. |
Modelling Slug Flow in ANSYS Fluent VOF. | OliverMechEng2208 | Fluent Multiphase | 1 | March 18, 2015 05:45 |
Free surface flow in Ansys Fluent | Tanjina | Fluent Multiphase | 11 | April 16, 2014 11:52 |
Turbulent flow of non-Newtonian fluids in Ansys 13 Fluent | emil | FLUENT | 2 | February 25, 2013 04:26 |
Comparison between Solidworks Flow Simulation and Ansys Fluent | Bruce828 | Main CFD Forum | 5 | February 23, 2013 10:13 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 12:07 |
