double pipe heat exchangers: difficulty in defining conditions to initialize |
May 20, 2015, 13:24 |
Khaled
Rep Power: 17 |
I want to simulate the double pipe heat exchangers
The double pipe or the tube in tube type heat exchanger consists of one pipe placed concentrically inside another pipe having a greater diameter. The flow in this configuration cane be of two types: parallel flow and counter-flow. Boundary Conditions: Inner Inlet: Velocity Inlet 0.95 m/s (350 K); Inner Outlet: Pressure Outlet Outer Inlet: Velocity Inlet 0.85 m/s (280 K); Outer Outlet: Pressure Outlet What is the condition that I have to choose to initialize my simulation? |
May 24, 2015, 12:28 |
Jim
Rep Power: 10 |
"What is the condition that I have to choose to initialize my simulation? "
can you give more information on what it is you're looking for ? |
May 26, 2015, 06:02 |
Hi
Initialize is only a guess to start calculation. Initialize only affect on convergence speed. |
simulation of Double pipe heat exchangers in FLUENT | teguhtf | FLUENT | 1 | November 6, 2014 02:42 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
[ANSYS Meshing] double pipe heat exchanger meshing in ICEM CFD | chitra | ANSYS Meshing & Geometry | 0 | April 13, 2013 08:36 |
Double Pipe 16mm Heat Exchanger | davidrlc89 | CFX | 0 | March 29, 2013 22:33 |
