Gravity Effects in Porous Media
Old   May 27, 2015, 13:31
Post Gravity Effects in Porous Media
Thota
Thota is on a distinguished road
Hi Everyone,
I modeled two 3D tubes; one porous and one hollow tube in GAMBIT and I am trying to find out the total heat transfer rate in both the cases by using FLUENT. The flow inside the tube is free convection and both ends of the tubes are at two different (higher and lower) temperatures.
I could get the different values of total heat transfer rate in case of gas flow in hollow tube with orientation with respect to gravity. But in the case of porous media, the result remains same with different orientations of tube with respect to gravity.
What could be the reason for no change in total heat transfer rate in case of porous media?
Please help me in understanding this problem!
Thota is offline   Reply With Quote
Old   May 27, 2015, 14:04
jpando is on a distinguished road
Are you using isotropic porous media coefficients or does you flow have a specified direction?
It is also possible that the value for porosity is affecting the result. Heat transfer within a porous media using the porosity to calculate heat transfer to surrounding cells.
jpando is offline   Reply With Quote
Old   May 27, 2015, 14:16
Thota
I have calculated the viscous and inertial resistance coefficients of particular porous material and using the same values in all directions. Is that wrong?
If i don't select porous media and mention porosity value only will solve the problem?
Old   May 27, 2015, 14:27
Thota
I mean mentioning porosity value and porous media coefficients..without mentioning it is porous zone?
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 7 May 14, 2020 16:34
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 04:09
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 10:34
species mass source in porous media ? PK FLUENT 0 February 16, 2007 11:12
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 15:16
