Text Command to iterate a transient simulation |
April 29, 2012, 09:54 |
Deside
Rep Power: 16 |
Hi All, i am failing to figure out the text command to carry a transient simulation after enabling Automatic Initialize and modify case. Options available after /solve > are /animate, /monitors, /execute-commands, /patch, /initialize and /set. I seem not to get anything that gets me to iterate using text user interface. I need this to comple my journal file. Can you kindly assist.
Many thanks in advance. Best regards!!! |
April 29, 2012, 10:44 |
#2 | |
Lucky
Rep Power: 65 |
solve dual-time iterate ## #### |
April 29, 2012, 11:33 |
Deside
Rep Power: 16 |
Hi Lucky, thank you for the response. When i use /solve/dual-time-iterate/10000/40 i get Invalid command [dual-time-iterate]. This command is only working when i disable Automatic Initialize and modify case. I look forward to your kind further help.
Best regards!!! |
April 29, 2012, 11:36 |
#4 | |
Lucky
Rep Power: 65 |
April 30, 2012, 01:59 |
Deside
Rep Power: 16 |
Hi Lucky, many thanks for the responses. I managed to figure it out......!!!
May 29, 2015, 12:32 |
Command line scripting for running transient simulations in Fluent
Rohini Bala Chandran
Rep Power: 14 |
I am having the same issue of being unable to use solve dual-time-iterate when I turn on the Automatically Initialize/Modify Case file. How did you get over this problem? I don't seem to be able to run my solution without actually manually clicking on the "calculate" button on the gui. Will you please let me know how you resolved your issue? Thanks, Rohini |
How to integrate variable in a transient simulation? | nprace | CFX | 4 | January 9, 2012 08:59 |
Turbine: Transient Simulation Problem | John C. | CFX | 7 | December 5, 2011 08:31 |
about transient radiations simulation | waradevivek | FLUENT | 0 | October 17, 2011 10:16 |
Beginning a Transient Simulation | Norflow | CFX | 2 | October 7, 2011 00:38 |
Steady-state simulation to start a transient simulation | smagmon | CFX | 2 | May 18, 2009 03:59 |
