May 31, 2015, 23:28 |
Parallel (MPI) error
AaronSyu
Rep Power: 10 |
Hi everyone
There is a problem occurred when I using Parallel to simulate with Fluent 15.0 x64/Windows 7 64 bit / Intel MPI/ Visual studio 2008 Error message shows after 2 time-steps when I try to output fluid field(Pressure coefficient, velocity ....etc.) for my UDF, it can run well on Fluent 14 What I've try: 1. re-install Intel MPI 2. uncheck "double Precision" 3. disable fire wall 4. checked Windows .frameWork 3.5 is running 5. computed by using serial processor and it runs good I'v google everything as possible but still can't solve this problem. Can someone help me please?? ================================== Node 999999: Process 6860: Received signal SIGSEGV. ================================== vis_StateClear: ierr= 8 SYS_ERROR_OPERATION An operation failed in current state Entity number mismatch unable to read the cmd header on the pmi context, Error = -1 . Error posting readv (10054) unable to read the cmd header on the pmi context, Error = -1 . . . received suspend command for a pmi context that doesn't exist: unmatched id = 19 received suspend command for a pmi context that doesn't exist: unmatched id = 17 received suspend command for a pmi context that doesn't exist: unmatched id = 16 received suspend command for a pmi context that doesn't exist: unmatched id = 15 received suspend command for a pmi context that doesn't exist: unmatched id = 14 received suspend command for a pmi context that doesn't exist: unmatched id = 13 received suspend command for a pmi context that doesn't exist: unmatched id = 12 . . . job aborted: rank: node: exit code[: error message] 0: user-PC: 2: process 0 exited without calling finalize 1: user-PC: 2: process 1 exited without calling finalize 2: user-PC: 2: process 2 exited without calling finalize 3: user-PC: 2: process 3 exited without calling finalize . . . received suspend command for a pmi context that doesn't exist: unmatched id = 8 received suspend command for a pmi context that doesn't exist: unmatched id = 7 received suspend command for a pmi context that doesn't exist: unmatched id = 6 received suspend command for a pmi context that doesn't exist: unmatched id = 5 received suspend command for a pmi context that doesn't exist: unmatched id = 4 received suspend command for a pmi context that doesn't exist: unmatched id = 3 . . . The fl process could not be started. Error: CX_Send_Help_Command, could not get Help server port = 0. |
July 10, 2015, 08:28 |
#2 | |
karim
Rep Power: 10 |
thanks |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 20:16 |
