April 8, 2022, 11:12 |
Duplicated case leads to different results
Rep Power: 4 |
Hello!
I am currently simulating some basic flows to learn fluent and the following strange problem occured. I have created a case, duplicated it and solved both of them. The results from both cases are identical as they should be. Now I initialised both cases again and ran them once more (with same settings). But now the results differ from each other and I dont know why. Do you know where the problem might be? Update: I initalised both cases for the third time and run them again and now the results are identical again. Now I'm beyond confused. Last edited by Leoma; April 8, 2022 at 11:33. Reason: Additional Information |
different results, initialising |
Rising Bubble Test Case Using interFoam: Unrealistic Results?! | farazarbabi | OpenFOAM Running, Solving & CFD | 21 | May 7, 2021 08:45 |
Crazy results on a simple case, no turbulence decay | stardust23 | OpenFOAM Running, Solving & CFD | 3 | March 26, 2020 05:18 |
how to map results from steady state run to tranient case? | phsieh2005 | OpenFOAM Running, Solving & CFD | 2 | November 7, 2010 06:20 |
Changing the grid on the same set-up | Katya | FLUENT | 7 | October 8, 2009 16:31 |
Test Case results for Semi-Cylinder | shankar1221989 | Main CFD Forum | 0 | June 24, 2009 06:35 |
