Vibrating Residual values
Old   June 22, 2015, 11:09
Default Vibrating Residual values
Aidan
aptahaney is on a distinguished road
I am new to Ansys and I'm trying to carry out the 2D CFD analysis of a NACA0012 airfoil. Initially I started with a mesh convergence study, and everything was going to plan (after a few initial teething problems), until I increased the number of nodes in the mesh above 65,000.
When I used 55,000 and 60,000 nodes, I got similar answers (Coefficient of lift=0.54). Although this was slightly lower than I expected (0.62), I was trying to increase the mesh one more time to ensure that it had converged, when I ran into this problem
When I used 70,000 nodes, for example, the residual values start to vibrate excessively after about 6000 iterations. Does anyone have an idea why this is the case, and could you please suggest a solution?
Thanks a lot for any help.
Aidan
(Note: my mesh is fairly basic, in that I did not use the "Split Block" option in ICEM Meshing to refine the mesh around the airfoil - each time I used this, I got much lower values of the Coefficient of Lift and I'm not sure why. Therefore, I used a very basic mesh, similar to the one shown at the end of this video, where the mesh size grew as I move away from the airfoil: https://www.youtube.com/watch?v=EknKVAJGEJ8
aptahaney is offline   Reply With Quote
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 05:07
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Why RNGkepsilon model gives floating error shipman OpenFOAM Running, Solving & CFD 3 September 7, 2013 08:00
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
