Ansys Fluent and Paraview
Like Tree1Likes
  • 1 Post By NormalVector
Old   April 9, 2012, 15:04
Arrow Ansys Fluent and Paraview
aerospaceman is on a distinguished road
I don't know how many people want to do this, but chances are there is always someone...
So if anyone wants to run a simulation in Fluent and post-process in Paraview, the way that I've found to work is to export the solution data in Ensight format (binary).
Once that's done, you then have to change the extension to ".case" (information I've found scattered over various other treads; didn't discover it myself).
It then opens in Paraview, at least it worked for me.
I tried impoting the .dat files from Fluent,
but one they have loads of default variables I was not interested in, making it a very large file (200mb in my case, which times the number of time steps is a very large size),
and two,
I wasn't sucessful in doing so.
But if anyone is sucessful I'd be interested in knowing.
If anyone has any tips/best practise information I'd be really interested, as I'm new to Paraview.
aerospaceman is offline   Reply With Quote
Old   September 19, 2012, 11:33
Ugly Kid Joe
vmlxb6 is on a distinguished road
I have a 3D steady state simulation that I ran in Fluent and would like to analyse it using Paraview.
I tried different files to import it in paraview like .encase, .case and .cgns but all I can do is view surfaces. The contour symbol in the filter tool bar is not highlighted so I cannot view different contours.
any help is appreciated. Thanks.
vmlxb6 is offline   Reply With Quote
Old   September 19, 2012, 12:39
NormalVector's Avatar
NormalVector
NormalVector is on a distinguished road
and two,
I'm trying to postprocess Fluent in Paraview as well and I've run into my own problems so maybe someone here will be able help as the Paraview section of the forums is slightly under used. I'm trying to read a Fluent case as well as transient data files but whenever there is more than one data file for the case in my working directory, Paraview "cannot read data file". Any ideas?
As for importing steady state data (or one time step of a transient simulation), I think I've figured it out. With your .cas and .dat files in your working directory, open up the latest Paraview (3.14, haven't tried on earlier versions) and then open only the .cas file using the "Fluent Case Files" reader in the prompt box that pops up. I believe it automatically reads a data file of the same name.
Once you import your data, you'll notice you can't create stream tracers or contours. This is because the data is Cell Data and contour/stream tracers require Point Data. Apply the "Cell Data to Point Data" filter and you should now be able to apply contours or stream tracers.
I was also able to import into Paraview by exporting an Ensight file from Fluent but I'm not so sure that's the route to take with transient simulations.
arvindpj likes this.
NormalVector is offline   Reply With Quote
Old   September 19, 2012, 15:29
Ugly Kid Joe
Fantastic !!! thank you very much. it worked.
Old   September 19, 2012, 15:43
NormalVector
Sure, no problem. If you ever find out how to load Fluent transient data into Paraview, please let me know. I guess I'll just keep searching. : /
Old   November 16, 2012, 08:37
Cheng Jie
jiec827 is on a distinguished road
My Paraview stops running as soon as a FLUENT.cas was selected?
WHY? Could you give me a hand?
PS:win7 x64 Paraview 3.14.1 Fluent 13.0
jiec827 is offline   Reply With Quote
Old   June 18, 2014, 07:46
Edgar90's Avatar
Edgar Perez
Edgar90 is on a distinguished road
I have exactly the same problem. When I try to open the .cas file the program does not respond anymore. My .cas file is around 750 MB
Edgar90 is offline   Reply With Quote
Old   March 11, 2015, 04:04
Default steady fluent to paraview
Naresh Yathuru
Naresh yathuru is on a distinguished road
Hi everyone,
I m trying to post process my steady fluent simulation using paraview for comparing the openfoam and fluent results.
so i opened the fluent .cas file in paraview . using celldatatopoint data in filter option i got a good plot.
but the problem i have here is that the velocity is shown as components of x ,y,z did anyone had the similar problem?
Can someone help me. what am i missing here?
Naresh yathuru is offline   Reply With Quote
Old   June 24, 2015, 08:46
Jakob Hærvig
hrvig is on a distinguished road
I would suggest that you export as ensight gold data format. You will get a file called .encase which you can rename to .case and open it directly in paraview. This approach should work flawlessly
hrvig is offline   Reply With Quote
fluent, paraview, post-processing
Fluent 6.3 export to Paraview 3.10 Silence19 FLUENT 4 May 15, 2013 03:13
Fluent to Paraview Lilly FLUENT 2 September 19, 2012 12:40
Recovering Fluent surfaces in ParaView alemenchaca FLUENT 6 August 11, 2011 15:52
Rendering Fluent Data in Paraview burk FLUENT 4 July 7, 2008 03:32
[General] Fluent to Paraview Nick ParaView 6 April 16, 2008 11:25
