Multiphase mixture Cavitation model for bearings |
July 14, 2015, 05:15 |
Vedant
Rep Power: 10 |
Hi friends! I am simulating journal bearings in which i am using mixture model of multiphase flow. In that i have doubts in Cavitation model, which i am using, as in attached fig.In this model, what is the vaporization pressure and condensation factor? Is it constant value for particular fluid ? Where i will get these properties?I am using SAE40 oil. So what will these values for SAE 40 oil? If these values are not available then what are the default values i can take in order to get converged solution?
Plz help guys. Thanks in advance. |
A question about UDF utility in mixture and multiphase model | aleisia | Fluent UDF and Scheme Programming | 0 | June 7, 2011 16:32 |
MULTIPHASE - FREE SURFACE & MIXTURE MODEL | Aris | FLUENT | 3 | April 28, 2009 11:46 |
air and water vapour mixture - multiphase model | Saba | FLUENT | 0 | February 10, 2009 12:05 |
UDF for the mixture model | khar nab | FLUENT | 0 | July 31, 2008 06:29 |
Mixture Model (cavitation) | Victor | FLUENT | 3 | April 5, 2005 04:38 |
