DPM UDF particle position
Old   October 29, 2004, 10:25
Default DPM UDF particle position
Tom
I try to find the particle position using macro P_POS(p)[i]. But when Fluent interpret the source code, an error "undeclared variable" occurred.
Why? How to solve this problem?
Thank you in advance. Tom
Old   October 29, 2004, 13:18
Default Re: DPM UDF particle position
Umesh
It is hard to tell with the given details.
It could be because of any variable, which hasn't been declared before its use.
One other thing i get in mind is, does your UDF supplies the pointer p access? If not, you need to provide that with the argument ' Tracked_Particle *p '.
Old   October 29, 2004, 13:30
Tom
Hello, Umesh, Thank you. I found out it is not necessary to provide the argument ' Tracked_Particle *p '. The following is a very simple UDF. But the error still exists.
#include "udf.h"
DEFINE_DPM_BODY_FORCE(particle_body_force, p, i) {
real bforce = 0.0;
real x = P_POS(p)[1];
return (bforce/P_MASS(p)); }
Waiting for your reply. Thanks. Tom.
Old   October 29, 2004, 14:08
Umesh
Hi Tom,
I think the problem is with the definition of x. I think, P_POS(p)[i] is a position vector and so you need to define x as a vector with syntax, 'real x[ND_ND]'. Then, you can access the x component of the position with, x[1] = P_POS(p)[1]. Try this out. It may solve yr problem.
Old   November 1, 2004, 15:22
David
hello,
I would like to get the face area the particle is crossing to get the volume flux.
But I'm not sure which variable I should use and how:
C_FACE(cell,cthread)?
#include "udf.h"
#include "dpm.h"
#include "surf.h"
#define REMOVE_PARCELS FALSE
#define P_CELL(P) RP_CELL(&((P)->cCell)) /* Non-standard macros */
#define P_CELL_THREAD(P) RP_THREAD(&((P)->cCell))
real volume;
real face;
Particle *p;
cell_t cell;
face_t f;
Thread *cthread;
real r, x, y;
DEFINE_DPM_OUTPUT(Discrete_phase_sample,header,fp, p,t,plane)
#if RP_3D
real flow_time = solver_par.flow_time;
cell = P_CELL(p); /* Get the cell and thread that the particle
is currently in */
cthread = P_CELL_THREAD(p);
face = C_FACE(cell,cthread);
if(header)
cxprintf(fp," #R [m] x-velocity[m/s] y-velocity[m/s] z-velocity[m/s] Drop Diameter[m] face \n");
if(NULLP(p))
return;
x = p->state.pos[0];
y = p->state.pos[1];
r = sqrt(SQR(x) + SQR(y));
cxprintf(fp," %e %f %f %f %e %e \n",
r,p->state.V[0],p->state.V[1],p->state.V[2],P_DIAM(p),volume);
#endif
#if REMOVE_PARCELS
p->stream_index=-1;
#endif
Can anyone help?
thank you
David
Old   November 5, 2004, 07:59
annie
i think, when you use UDF in DPM, you must compile the UDF, rather than interpret the file.
When you compile any udf, you muss install the VC++ in your computer, then all is ok.
Old   November 5, 2004, 17:46
Tom
Hello, Annie, Thank you. It works. Tom
Old   December 25, 2010, 02:39
NH
NH_Aus is on a distinguished road
Send a message via Skype™ to NH_Aus
I need to know the shortest distance of wall from the particle location. I know I can use C_WALL_DIST(c,t) this, but how do I connect from:
px=P_POS(p)[0] ;
py=P_POS(p)[1] ;
pz=P_POS(p)[2] ;
NH_Aus is offline   Reply With Quote
Old   July 25, 2015, 12:30
Parham Vatankhah
Parham Vatankhah is on a distinguished road
Hi all,
By interpreting UDFs you can not access particles position.
Generally, it's better to compile complex UDFs.
best regards,
Parham
Parham Vatankhah is offline   Reply With Quote
DPM particle time step amos FLUENT 1 January 4, 2020 08:46
Add Mass to a Particle with UDF (DPM) sega Fluent UDF and Scheme Programming 6 October 24, 2013 22:14
DPM particle tracking parisa- Main CFD Forum 2 June 15, 2011 05:12
help with DPM particle position Josh FLUENT 2 February 16, 2006 12:10
DPM; particle seeded / deleted by UDF Laika FLUENT 6 January 22, 2006 23:40
