Home > Forums > FLUENT
Error of Interface
Old   August 6, 2015, 04:22
Default Error of Interface
Aja
aja1345 is on a distinguished road
I am simulating a turbine and I had explained this model and boundary conditions in the following link:
periodic condition and Rotary inner domain
This turbine have 6 blades((360/6)=60 deg=angle between blades). Due to the circumferential symmetry, only one sixth of the annulus has been computed, imposing periodic boundary conditions in the tangential direction. The computational domain has been restricted in the axial direction to four chord lengths upstream and six chord lengths downstream of the blade.
So, I had created periodic condition in Gambit, But when I watched the following video, I think that I should create two Interface.
http://www.4shared.com/video/VwtSUbM...Blade_FSI.html
However, I made two wall in circumferential sides of the domain by using Gambit. Then, I defined these two walls to interface in fluent. But when I want to initialize in The Solution Initialization panel, I face the following error:
Why does this happen?
Thanks,
Best,
Aja
aja1345 is offline   Reply With Quote
Old   August 9, 2015, 23:59
Aja
Dear friends,
I clicked the following options:
Define>grid interfaces..
according the following figure, I done these works:
But when I click option of List in above figure, the following sentence is appeared:
*intersection zones are not created until initialization*
Why?
I am grateful that guide me.
Thanks,
Best,
Aja
Thread Tools
Trackbacks are On
sliding mesh problem in CFX Saima CFX 45 September 22, 2015 10:53
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 10 June 16, 2015 15:48
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
